Cancel search
LKC Forums will no longer be available after April.
Please use the HP Support Community to ask questions and share solutions.
54" Cutter won't read barcode
#1 CCSI_Adam 5 years ago
I have tried everything under the sun to get the cutter working again. I've read every post I can find here hoping someone would have a similar issue with a solution. The cutter just won't even bother to search for the barcode most times. It's behavior is completely erratic. Sometimes the sensor will scan right past it until it gets up into the art and is looking for the barcode up there, sometimes it will VERY slowly scan all the way down the sheet and error out, sometimes it just freezes with "PLEASE WAIT" on the display, sometimes it will look like it reads the barcode just fine then says it can't see it. It takes me hours to get it to cut one job. A combination of restarting everything, repositioning and luck. Any ideas what could possibly be happening? I've uploaded two videos to a shared google photos album: https://photos.app.goo.gl/7JQxBypFNxQucaLU8
#2 HP-ColorGuy 5 years ago
In the videos, I see a couple of things that might be contributing to the issue. First, the right-most pinch roller should be positioned outside of (between the edge of the sheet and the black registration mark) of the registration mark. In the video, it is located inside of the mark - see attached screen grab that shows the incorrect position of the PR assembly. Make sure that the leftmost PR assy is also placed outside of the left registration marks. Al 4 PR assy need to be in contact with the media during scanning and cutting. Second, the sheet is not loaded square in the cutter. Note the media movement which scanning to barcode. This is likely resulting in an incomplete read of the barcode. Load the sheet squarely in the cutter, so that the media is stationary while the barcode is being scanned. Next, ensure that the cutter firmware is up to date - md9985_035. Here is a link to obtain current firmware for the cutter and printer: https://support.hp.com/us-en/drivers/selfservice/hp-latex-335-print-and-cut-solution/15946111 Finally, make sure that the OPOS sensor is dropping into physical contact ( it should touch the media) with the media when scanning barcode and searching for registration marks. Hope this helps.
Was this helpful?Yes1 No0
100% of users thought this content was helpful.
How can we improve it?
#3 Srikant9 4 years ago
I also had the same issue. I was looking for a reliable barcode scanner for my android device for free. And luckily found it. This barcode scanner app helps me to scan anything for free. The domain URL is here https://pageloot.com/barcode-scanner. It's very easy to scan a barcode logo. You just need to follow up 3 steps below- Target the barcode logo Make sure you have it clearly visible on the camera Done – now you see the information And your job is done. All the best!
Was this helpful?Yes0 No2
The opinions expressed above are the personal opinions of the authors, not of HP.
Remember
To make recommendations or participate please Sign In and post a message.
Latest conversations HP Latex
HP Latex Blog
What was your overall satisfaction with LKC?
  • Very unsatisfied
  • 1
  • 2
  • 3
  • 4
  • 5
  • Very satisfied
Thanks for your collaboration
To provide additional details, click here.
