Very unsatisfied
1
2
3
4
5
Very satisfied
So I use SAI Production Manager, Has anyone else had this issue or know what can be done to fix it. Basically One day out of the blue, The Length of each print started coming up 1/8 inch short per foot. So we do a lot of 48x96 and then it turns out to be 48 x 94. It was never an issue in the past, nothing changed. It does change also randomly, some days it will come out only 1//4 inch short and sometimes 1 inch, but mostly 2inches... PLEASE I hope someone knows what's going on with this??? We Also tried using production manager and played around with the settings and nothing, The Sizes are definitely correct in the software, but it is not coming out that way. We Also have an Epson SC68-600 and that prints perfectly fine.
