Cancel search
Latex 52 Cutter not cutting ovals and circles accurately
#1 northcoastTIM 6 years ago
Hi everyone new owner of a 315 print and cut and the 54" HP Latex Cutter not 52". Prints great and cuts straight lines great. Whenever I have a circle or oval contour cut it is always "skewed" in that it's off center. Very tight at the top right and wide at bottom left. Any assistance is on how to adjust or video location to help is appreciated.
#2 HP Daniela Ciolompea 6 years ago
#1 Hi @northcoastTIM, In case the contour does not match the printed design, check the following items: • The shift calibration determining the offset between the knife tip and the OPOS sensor may be off. Run the OPOS offset calibration test. [MENU] – [SYSTEM SETUP] – [CALIBRATIONS] – [CAL. OPOS]. • The sensitivity of the OPOS sensor may not be set correct for the media used. Check OPOS sensitivity setting. [MENU] – [SYSTEM SETUP] – [CALIBRATIONS] – [CAL.MEDIA] I hope this helps fix the issue.
Was this helpful?Yes1 No0
100% of users thought this content was helpful.
How can we improve it?
The opinions expressed above are the personal opinions of the authors, not of HP.
Remember
To make recommendations or participate please Sign In and post a message.
Latest conversations HP Latex
HP Latex Blog
What was your overall satisfaction with LKC?
  • Very unsatisfied
  • 1
  • 2
  • 3
  • 4
  • 5
  • Very satisfied
Thanks for your collaboration
To provide additional details, click here.
