Cancel search
How to Fix an HP Printer Offline Issue on Mac
#1 skchaudhary946352963 9 months ago
Experiencing an “HP Printer Offline issue” error on your Mac can be frustrating, but several straightforward steps can help restore the connection. Check Printer and Network Connections Ensure that your printer is properly connected to your Mac. For wireless printers, verify that both the printer and your Mac are connected to the same Wi-Fi network. If using a USB connection, confirm that the cable is securely plugged into both the printer and your Mac. Restart Devices Power cycle your printer and restart your Mac. This can resolve minor connectivity issues and refresh the connection between devices. Set Printer to Online Status Sometimes, the printer may appear offline due to settings. To set your printer online: Open System Preferences > Printers & Scanners. Right-click (or Control-click) on your HP printer in the list. Select “Set as Default Printer”. Ensure “Use Printer Offline” is unchecked. Remove and Re-add Printer Reinstalling the printer can resolve persistent issues: Navigate to System Preferences > Printers & Scanners. Select your HP printer and click the minus (-) button to remove it. Click the plus (+) button to add the printer back. Choose your printer from the list and ensure “Use” is set to “AirPrint”. Reset the Printing System Resetting the printing system can clear all printers and reset settings: Open System Preferences > Printers & Scanners. Right-click (or Control-click) on the printer list and select “Reset printing system”. Confirm the reset and re-add your printer afterward. Update or Reinstall Printer Drivers Outdated drivers can cause offline errors: Visit the HP Support website and download the latest drivers for your printer model. Install the drivers and restart your Mac. Check Firewall or Antivirus Settings Security software may block printer communication: Temporarily disable your firewall or antivirus software. Attempt to print. If successful, adjust your security settings to allow printer communication ‘’Resolve Offline Hp printer on Mac’’. Reconnect Printer to Wi-Fi Network Re-establishing the Wi-Fi connection can help: On the printer’s control panel, navigate to Wi-Fi settings. Select your current Wi-Fi network and enter the password. Verify the printer shows as online on your Mac.
The opinions expressed above are the personal opinions of the authors, not of HP.
Remember
To make recommendations or participate please Sign In and post a message.
Latest conversations HP Latex
HP Latex Blog
What was your overall satisfaction with LKC?
  • Very unsatisfied
  • 1
  • 2
  • 3
  • 4
  • 5
  • Very satisfied
Thanks for your collaboration
To provide additional details, click here.
