Cancel search
LKC Forums will no longer be available after April.
Please use the HP Support Community to ask questions and share solutions.
I'm experiencing issues with my HP 315 print and cut solution when using software other than Flexi
#1 MBean02850296 a year ago
I'm experiencing issues with my HP 315 print and cut solution when using software other than Flexi. While cutting works perfectly with Flexi, both Onyx and VinylMaster show the same problem: after reading the right marks and first left mark, the cutter moves too far left beyond the substrate instead of reading down the line. Since Flexi was bundled with the machine, I wonder if the cutter is programmed to only work properly with it. Any suggestions would be appreciated.
#1 said I'm experiencing issues with my HP 315 print and cut solution when using software other than Flexi. While cutting works perfectly with Flexi, both Onyx and VinylMaster show the same problem: after reading the right marks and first left mark, the cutter moves too far left beyond the substrate instead of reading down the line. Since Flexi was bundled with the machine, I wonder if the cutter is programmed to only work properly with it. Any suggestions would be appreciated. Reply Sounds like a registration mark compatibility issue. Flexi probably uses a specific mark format the cutter is tuned for. Check if Onyx or VinylMaster let you adjust the mark type/layout to match Flexi’s. Also make sure firmware and drivers are up to date.
Was this helpful?Yes1 No0
100% of users thought this content was helpful.
How can we improve it?
#3 MBean02850296 12 months ago
#2 Thanks for your replying. The problem solved after searching HP forum and asked my boss
Was this helpful?Yes2 No0
The opinions expressed above are the personal opinions of the authors, not of HP.
Remember
To make recommendations or participate please Sign In and post a message.
Latest conversations HP Latex
HP Latex Blog
What was your overall satisfaction with LKC?
  • Very unsatisfied
  • 1
  • 2
  • 3
  • 4
  • 5
  • Very satisfied
Thanks for your collaboration
To provide additional details, click here.
