Cancel search
Latex 700W Color Calibration is in expired status despite low print head usage.
#1 hatano22103 a year ago
Multiple original material presets suddenly switch to color calibration expired status. This is not after the print head has been replaced. The print head usage is also small. We are having trouble getting color calibration again for all material presets after this has been confirmed. Does anyone know of a solution to this phenomenon?
#2 HP Daniela Ciolompea a year ago
Hi @hatano22103, Can you please confirm which profiles are impacted? You mentioned multiple original material presets but not which one has the issue. We need more details to try and reproduce the issue with our printers.
Was this helpful?Yes0 No0
How can we improve it?
#3 hatano22103 a year ago
Hi @HP Daniela Ciolompea, We can provide you with all of the profiles (OMS files) that have been confirmed to be abruptly expired for color calibration. How do I submit them? There are 11 different profiles.
#4 HP Daniela Ciolompea a year ago
Hi @hatano22103, Please drop me an email at lkc@hp.com.
#5 hatano22103 a year ago
Hi @HP Daniela Ciolompea, I have sent it to you by email, please check it out.
#6 reply22144 a year ago
It seems like you're encountering an issue with the color calibration on your Latex 700W printer despite low print head usage. Here are a few steps you can take to troubleshoot the problem: Check Calibration Settings. Ensure that the calibration settings are correctly configured in the printer's settings menu. Sometimes, settings can be inadvertently changed, causing calibration issues. Perform Manual Calibration: If the automatic calibration is not working, you can try performing a manual calibration. This typically involves printing a calibration test pattern and adjusting the color settings accordingly.
#7 printertales 2 months ago
I’ve had this issue before. It sounds like a software glitch or a calibration setting issue. Here's what helped me: Reset the Printer: Power cycle it, or unplug for a minute to clear any temporary errors. Recalibrate the Printer: Go to the printer’s settings and manually trigger the color calibration process again. Check the Firmware: Make sure it’s up to date—sometimes bugs are fixed in new updates. Recreate Material Presets: Delete the current presets and create new ones. Sometimes old presets get corrupted. Hopefully, this helps!
The opinions expressed above are the personal opinions of the authors, not of HP.
Remember
To make recommendations or participate please Sign In and post a message.
Latest conversations HP Latex
HP Latex Blog
What was your overall satisfaction with LKC?
  • Very unsatisfied
  • 1
  • 2
  • 3
  • 4
  • 5
  • Very satisfied
Thanks for your collaboration
To provide additional details, click here.
