Cancel search
LKC Forums will no longer be available after April.
Please use the HP Support Community to ask questions and share solutions.
problem with print
HP Latex 310 Printer
#1 rar 9 years ago
Hello I have problem with my HP Latex 310 When i start printing black CMYK 100C100M100Y100K everything is OK But after printing a 20 cm color fades as if out of all color ink /look on images/ services support on my country send me answer that is faulty ink management.When printing in color does not make me this. Thank you for your response.
#2 dypinc 9 years ago
Why would ever want to print black using CMYK 100C100M100Y100K. Haven't you noticed that the best black with latex ink is 100K. In fact most RIPs have a setting to print pure primaries or black as inkjet black which turns color management off if you want to print the pure 100% colors of the printer, like your linearization targets. It sounds like your getting ink starvation. Slow your printer down by increasing the passes or adding inter-pass delay if you want to print like that.
Was this helpful?Yes0 No0
How can we improve it?
#3 rar 9 years ago
Before, I still print like this and did not make printer this problem. Could this problem cause dirty contacts on the optimiser head ?
#4 HP-MarcM 9 years ago
Hi rar, For your description, your issue may be caused by one of this two things: 1- Your Optimizer printhead has some issue. The the color shift may be visible in all colors. I'll recommend you to change the printhead. 2- The issue is caused by the media. I'll recommend you to use another media and please let me know which media were you using. Hope this helps.
#5 rar 9 years ago
1-I try change optimiser head and any changes with print black 100C100M100Y100K When i set old head optimiser and clean contacts on head problem the problem disappears. 2- I printing on this media before at many times with no problem. On color print i have no problem
#6 paulelw 6 years ago
#5 Check ALL Printheads health with diagnostic image. Replace any Printheads not providing suitable quality. Do some test swatches to get correct colour. Avoid printing 100% of all CMYK values. You will be using too much ink to get a suitable coverage and it would be unnecessary. You can use less ink and get better results.
Was this helpful?Yes1 No0
100% of users thought this content was helpful.
The opinions expressed above are the personal opinions of the authors, not of HP.
Remember
To make recommendations or participate please Sign In and post a message.
Latest conversations HP Latex
HP Latex Blog
What was your overall satisfaction with LKC?
  • Very unsatisfied
  • 1
  • 2
  • 3
  • 4
  • 5
  • Very satisfied
Thanks for your collaboration
To provide additional details, click here.
