Cancel search
LKC Forums will no longer be available after April.
Please use the HP Support Community to ask questions and share solutions.
Traffic color problems and color calibration issue
#1 tehno.trafic20393 2 years ago
We bought last year Hp 700 latex printer and we have some problems with him, wen we try to print traffic colors. First. On the printer displaying the "color calibration failed" when i try to calibrate the printer with 3M 3930 reflective film. When we load the substrate and chose HIP 3930 Series Traffic Colors v3 on the display appear: Color calibration obsolete. I try to calibrate several times, the printer print the calibration image, after that start to scan the pattern but after 50% stop scaning and show the message|: Color calibration failed. I veryfied the printer settings, I have the latest firmware (PLS_50_23_39.1), I try to restart, clean the printer without result. Another problem is with this traffic colors. We bought Production Manager Authorized 3M Traffic Edition 21 and FlexiPrint from SAi. In the Production Manager Authorized 3M Traffic Edition 21 we try to print traffic colors for test but no one. We found only CMYK test. We try to contact SAi but they send us to the reseller. Please advise what can I do. We want to print traffic colors for traffic signs.
#2 HP Daniela Ciolompea 2 years ago
Hi @tehno.trafic20393, To perform the Color Calibration in Reflective 3M media follow the steps below: Once the substrate preset is installed, the color calibration must be performed for this media preset. It cannot be done physically on the reflective sheeting; it needs to be performed on a white self-adhesive vinyl instead. In this case, 3M IJ180mC-10 is recommended. IMPORTANT: Select the reflective sheeting you intend to use for your traffic sign Jobs. Advance the substrate and attach it to the TUR. Cut it in a “V” shape, as shown in the image below, and attach the substrate from the center. Then, activate the TUR by completing a full rotation of it. Check print image-quality status. In the Optimize quality menu, perform the printhead nozzle check and printhead alignment. Launch color calibration. In the Optimize quality menu, press Color calibration and select Start. Color calibration > Calibration target is printed > The patches are automatically measured. See the attached document where the workflow is explained in detail with screenshots. I hope this solves the issue.
Was this helpful?Yes1 No0
100% of users thought this content was helpful.
How can we improve it?
#3 tehno.trafic20393 2 years ago
Thank you for response. But the two different material (3M 3690 and have 2 different white point, wich means they reflect light diferently. This will cause to color appear different on the materials., even if they are printed using the same color profile.
Was this helpful?Yes0 No0
#4 tehno.trafic20393 2 years ago
Hello. I try collor calibration, following you steps. When the calibration secvence reach 70% I receive error message. See atachements. What can i do?
The opinions expressed above are the personal opinions of the authors, not of HP.
Remember
To make recommendations or participate please Sign In and post a message.
Latest conversations HP Latex
HP Latex Blog
What was your overall satisfaction with LKC?
  • Very unsatisfied
  • 1
  • 2
  • 3
  • 4
  • 5
  • Very satisfied
Thanks for your collaboration
To provide additional details, click here.
