How likely are you to recommend HP Latex Knowledge Center to a colleague?
Not at all likely
1
2
3
4
5
6
7
8
9
10
Extremely likely
#1 This might sound like I’m being condescending but it’s definitely not meant that way.
Have you checked the rollers and gcc vinyl cutter reviews? Mine refused to lock in place to begin with and that produced the same result as what you are describing.
Lock and unlock it a couple of times and try out different placements. I’ve found that mine works best with the “outer” roller (the one on the right) set appx 1/5 of the way in.
