Cancel search
LKC Forums will no longer be available after April.
Please use the HP Support Community to ask questions and share solutions.
HP Flexi Print & Cut 64bit will not be able to launch
#1 3 years ago
Following Sep/Oct, Microsoft patched to Win 11. HP Flexi Print and Cut 21 64-bit version cannot start (gets loaded Fonts), and it closes. There have been no reports of errors. The 32-bit version now launches perfectly and functions. I've uninstalled the Flexi program and then reinstalled it following the reboot, but I still have the same problem. Here is the URL check and solve it. Has anyone discovered a fix that works for the 64-bit version?
#2 kinorotpirsum2023 3 years ago
Try checking this URL Quite a few times I found many solutions there!
Was this helpful?Yes0 No0
How can we improve it?
#3 printertales 6 months ago
Hey, I had the same issue after the Win 11 update. What worked for me was running the 64-bit version in compatibility mode for Windows 10. Right-click the Flexi shortcut, go to Properties > Compatibility, and select ‘Run this program in compatibility mode for Windows 10’. Then restart your PC. Worth a shot!
#4 bradysmith800159006 4 months ago
HP Flexi Print & Cut 64-bit won’t launch usually due to driver or compatibility issues. Update Windows, run as admin, or reinstall. At Savionixa we’ve seen driver resets fix this fast.
The opinions expressed above are the personal opinions of the authors, not of HP.
Remember
To make recommendations or participate please Sign In and post a message.
Latest conversations HP Latex
HP Latex Blog
What was your overall satisfaction with LKC?
  • Very unsatisfied
  • 1
  • 2
  • 3
  • 4
  • 5
  • Very satisfied
Thanks for your collaboration
To provide additional details, click here.
