Cancel search
HP Latex 365- Multi-Color Marks in Print
#1 benjaminwinter12201 9 months ago
Have been having getting random multi-color lines in our print. Almost looking like the lines when you do a printhead alignment. At first they were smaller, now they are almost the length of the vinyl. We are using a Latex 365, vinyl media. Any idea on what could be causing the issue. Thanks in advance. (Pic attached)
#2 mi.guelw.atsonfv9931215314 2 months ago
#1 said
Have been having getting random multi-color lines in our print. Almost looking like the lines when you do a printhead alignment. At first they were smaller, now they are almost the length of the vinyl. We are using a Latex 365, vinyl media. Any idea on what could be causing the issue. Thanks in advance. (Pic attached) MyAccountAccess
Reply
Hello,
The random multi-color lines on the prints from the Latex 365 could be caused by several factors: printhead alignment, media misalignment, printhead contamination, or firmware/software issues. Initially small, the lines have grown, indicating a worsening problem. To troubleshoot, ensure proper printhead alignment, check vinyl media alignment, and clean printheads. Also, update firmware/drivers and inspect the print settings. If the issue persists, contact HP customer support or a certified technician for a thorough diagnosis and resolution. Regular maintenance and adherence to manufacturer guidelines can prevent future occurrences.
Was this helpful?Yes0 No0
How can we improve it?
The opinions expressed above are the personal opinions of the authors, not of HP.
Remember
To make recommendations or participate please Sign In and post a message.
Latest conversations HP Latex
HP Latex Blog
How likely are you to recommend HP Large Format Knowledge Center to a colleague?
  • Not at all likely
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
  • 10
  • Extremely likely
Thanks for your collaboration
To provide additional details, click here.
