Cancel search
Window perf with blue solid printing with verticle streaks and horizontal banding. Onyx Thrive Rip
#1 -- removed 6757 -- 6 years ago
I have tried the HP one view Window perf profile and have changed the Saturation and the passes from 16 to 12 and 10 pass with 150 through 100 saturation and still get the streaks and bands. Any ideas? Thanks in advance
#2 ivoslbg5445 6 years ago
Nothing to worry, mostly it's the base silicone paper making these effects but the printed image is OK. Look closely to the printed image and see the holes - not much ink in there but the vinyl is solid... To be sure enough, cut printed image and install on flat surface... If that's not the case - you have to use certified substrate...
Was this helpful?Yes0 No0
How can we improve it?
#3 ivoslbg5445 6 years ago
#3 we had many different perfs, but honestly the result comes with a test of the material on flat surface, no matter if it's printed 6-8-10 passes, some rolls had problems like wrinkles when printing and you can see the defects on vinyl and silicone base, but not when installed and sometimes defects are real...if you have any doubts, print with this profile on regular self adhesive vinyl...but if surface is compromised... there's nothing you can do to avoid that...try regular self adhesive profile with more vacuum to window perf substrate...but much vacuum may cause vertical banding...
Was this helpful?Yes1 No0
100% of users thought this content was helpful.
The opinions expressed above are the personal opinions of the authors, not of HP.
Remember
To make recommendations or participate please Sign In and post a message.
Latest conversations HP Latex
HP Latex Blog
What was your overall satisfaction with LKC?
  • Very unsatisfied
  • 1
  • 2
  • 3
  • 4
  • 5
  • Very satisfied
Thanks for your collaboration
To provide additional details, click here.
