Cancel search
HP Latex 800W Print reflective vinyl problem.
#1 MichaelYeung 3 years ago
Dear All, Any people can print reflective vinyl on HP Latex 800W. Because I try to roll the reflective vinyl on Latex 800W. The vinyl can't move . have problem of the printer.Can't print. Any body have same problem?
#2 louislee73620530 a year ago
Hi, I think you should confirm that the reflective vinyl you're using is compatible with the HP Latex 800W printer. Some printers have limitations on the types of media they can handle, so it's important to ensure that the reflective vinyl is supported by the printer geometry dash scratch. Moreover, you need to examine the media handling system of the printer, including the rollers and media guides. Make sure they are properly aligned and adjusted to accommodate the thickness and rigidity of the reflective vinyl. Improper alignment or tension can cause issues with media movement.
Was this helpful?Yes0 No0
How can we improve it?
The opinions expressed above are the personal opinions of the authors, not of HP.
Remember
To make recommendations or participate please Sign In and post a message.
Latest conversations HP Latex
HP Latex Blog
What was your overall satisfaction with LKC?
  • Very unsatisfied
  • 1
  • 2
  • 3
  • 4
  • 5
  • Very satisfied
Thanks for your collaboration
To provide additional details, click here.
