Cancel search
SEG backlit with latex inks and textile materials
#1 Varribas 4 years ago
Dear comunity,
I’m trying to start a new project with edgelit aluminum frames and graphics with silicone edge.
All materials I’ve tested doesn’t give me a good result. Prints under 200% ink load looks washed out and prints with 200% and above looks great but as soon few tension is applied to fix the silicone to the edge the inks wrinkles.
Best material for me, now, is Samba FR from berger.
Has any one find a solution for this application with latex.?
Thank you very much. Kind regards
#2 Varribas 4 years ago
Sorry. English is not my main language.
There is a word “ wrinkles” would like to change to “cracks”
Was this helpful?Yes0 No0
How can we improve it?
#3 HP_RaúlVílchez 4 years ago
The printing options that you using are the correct ones:
  • Curing temperature at maximum
  • Over 200% ink to have saturated colors
  • Very slow speed
At the moment what we are recommending regarding durable textiles is to print with these two medias:
  • PrintTex Artist Mambo from Pongs
  • HP Durable Backlit Fabric
Please always use the https://www.printos.com/ml/#/medialocator to download the profiles of the medias and install them into your printer. By doing so you will you have the best results on your artwork.
I hope this helps
#4 Varribas 4 years ago
#3 Hi Raúl:
Thank you very much with your answer.
I've done tests with 16 and 20 Pass at 100 - 110ºC.
I'll try the following:
  • Increase curing temperature
  • Looking to catch up some test rolls of both materials mentioned above, and give them a chance.
I believe that the link of media locator you have mentioned is same as downloading the profile from the machine. Right ?
Hope tests will work better.
#5 HP-Sonia 4 years ago
#4 Yes, you can find the same profiles on both places.
The opinions expressed above are the personal opinions of the authors, not of HP.
Remember
To make recommendations or participate please Sign In and post a message.
Latest conversations HP Latex
HP Latex Blog
How likely are you to recommend HP Large Format Knowledge Center to a colleague?
  • Not at all likely
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
  • 10
  • Extremely likely
Thanks for your collaboration
To provide additional details, click here.
