How likely are you to recommend HP Latex Knowledge Center to a colleague?
Not at all likely
1
2
3
4
5
6
7
8
9
10
Extremely likely
HI everyone, I need help fixing a magenta cast in a 2nd gen latex.
I have a client with 3 L260 printers. 2 of them print the same and the third one adds a magenta cast to all the prints. We changed all the magenta and light magenta printheads and it still have the same cast.
I even reinstalled the profiles, reset, everything. Just so all the printers start from the same baseline.
Is there some sort of internal color calibration I can perform to "reset" the machine's baseline ? Or maybe change the voltage going to the heads... ?
Thanks !!
