Cancel search
Strange Problem after SMK3
HP Latex 300 Series
#1 df85 5 years ago
Hello guys, i'm having a quite strange issue with a customers Latex 360. I did the SMK3 yesterday and the printer looked good after the Service. Suddenly during a print it created a black bar throughout the print. I cancelled the Job and the display showed up a printhead error (C/K). The head didn't look good so i changed it and the following print was fine. Today my customer messaged me that the problem occured again. I did the SMK3 several times, with all adjusting routines, and never had this problem combined with it. Any ideas or experiences? Bets regards
#2 paulelw 5 years ago
#1 Check for any debris and ink around the printheads. Check Maintenance cartridge. is the fault occurring after a clean? Replace maintenance cartridge if it doesn't move to a fresh/new section. Swap between two same Cyan/Black printheads to see if it is printhead specific or otherwise. Try a print again(same one or a test) and failing that..... I would check the carriage PCB to make sure all connectors are in properly. You can also clean the contact for the metal cowl cover. I would then check the carriage flex cables for any damage or if any connections are lost. Clean and reinstall them or try another set. If the error is associated with a specific printhead slot check the flex cable for that slot.
Was this helpful?Yes0 No0
How can we improve it?
#3 Roy_Kuzmich 5 years ago
I agree with Paulelw and with Sonia. Clean the contacts, check the connections then you will have to replace parts if it continues. I have seen similar issue where the Carriage PCB solved the issue and in another instant the Trailing Cable solved the issue. Good Luck Roy K
The opinions expressed above are the personal opinions of the authors, not of HP.
Remember
To make recommendations or participate please Sign In and post a message.
Latest conversations HP Latex
HP Latex Blog
What was your overall satisfaction with LKC?
  • Very unsatisfied
  • 1
  • 2
  • 3
  • 4
  • 5
  • Very satisfied
Thanks for your collaboration
To provide additional details, click here.
