Cancel search
LKC Forums will no longer be available after April.
Please use the HP Support Community to ask questions and share solutions.
Adjusting color a little bit on caldera
HP Latex 360 Printer
#1 Renz 10 years ago
Hi, We did a lot of jobs with backlit film with L360 using caldera. Normally we use Natura ES690 color profile downloaded from HP media solutions locator. And we are very pleased for it. Sometimes, we got color differences on 1 or 2 rolls. On another printer, we can do little adjustment on Caldera's Easy Media. But for Latex, we can't adjust it because linearizations, ink limit settings are off, only ICC profile is on. How to adjust for example tweaking the linearization for better color? Thanks, Renz
#2 HP-MarcM 9 years ago
Hi Renz, Your request is really similar to this one. HP Latex 300 Ink Limit There is also an article in the blog that maight help you: HP Latex 300 Printer series ink density Hope this will help you.
Was this helpful?Yes0 No0
How can we improve it?
#3 Renz 9 years ago
Hi again Marc, Sorry for my late reply and thanks for your answers. What I need is re-adjust linearization curve not change ink limit. For example, on certain media the middle color tone is yellowish, then I open linearization curve in caldera and lowering a bit on middle of yellow curve. So, when I reprint on same media, the middle color not yellowish. I understand this wrong kind of way to get good color, but sometimes very useful if I get rush job. For frontlit media (paper, stickers, vinyl, banner) normally I just re-calibrate the color using printer software, but for backlit media I have no way to solve it. How to overcome this ? Thanks
#4 HP-MarcM 9 years ago
Hi Renz, Your method is really interesting, but I'm afraid that although it could work for some media, it is not working with backlit since re-adjusting an existent linearization may fix some issues but cause others. My recommendation is to use an external spectrophotometer in order to create a new ICC profile for your media. Hope this helps.
The opinions expressed above are the personal opinions of the authors, not of HP.
Remember
To make recommendations or participate please Sign In and post a message.
Latest conversations HP Latex
HP Latex Blog
What was your overall satisfaction with LKC?
  • Very unsatisfied
  • 1
  • 2
  • 3
  • 4
  • 5
  • Very satisfied
Thanks for your collaboration
To provide additional details, click here.
