Cancel search
LKC Forums will no longer be available after April.
Please use the HP Support Community to ask questions and share solutions.
cutter problem - Onyx can't read the cut marks correctly
#1 JayC a year ago
Hi, Trying to find some help here. Any ideas are highly appreciated! I have HP 315 print and cut solution and been using Flexi to cut and everything is ok. Recently I am trying to cut using Onyx but having issues. I also tried VinylMaster and it has the similar issue. This makes me believe the issue is not with the software but with the cutter. I wonder if the cutter is hard coded to work only with Flexi, which is bundled with the purchase of the machines. The issue is that when it was cutting, the cutter read the right side of the marks. Then it went across to the left side and read the first mark. After that, the cutter doesn't go down the line to read, instead it went further to the left trying to read beyond the substrate. I attached a picture showing the cutter position - the knife goes over to the left of the substrate. Thanks for your attention and looking forward to any help.
#2 eligible.fowl.uufz48841 a year ago
It seems like Onyx's inability to read the cut marks accurately can be frustrating. Have you considered using the Top Cloud to enhance your workflow? It may help streamline the cutting process by allowing better file management and any potential labeling adjustments you might need. Additionally, checking for software updates or community forums could provide additional insights into resolving this issue. https://www.google.com
Was this helpful?Yes0 No0
How can we improve it?
#3 JayC a year ago
#2 thanks for your comments. However not only Oynx but also VinylMaster has the similar problem. And it makes wonder if the cutter is programed to work only with Flexi.
#4 autobazar24 a year ago
Nicely explained.Tnx
#5 MBean02850296 a year ago
I have the same problem. How to fix it?
#6 printertales 11 months ago
#1 said Hi, Trying to find some help here. Any ideas are highly appreciated! I have HP 315 print and cut solution and been using Flexi to cut and everything is ok. Recently I am trying to cut using Onyx but having issues. I also tried VinylMaster and it has the similar issue. This makes me believe the issue is not with the software but with the cutter. I wonder if the cutter is hard coded to work only with Flexi, which is bundled with the purchase of the machines. The issue is that when it was cutting, the cutter read the right side of the marks. Then it went across to the left side and read the first mark. After that, the cutter doesn't go down the line to read, instead it went further to the left trying to read beyond the substrate. I attached a picture showing the cutter position - the knife goes over to the left of the substrate. Thanks for your attention and looking forward to any help. Reply Sounds like a mark reading/alignment issue, not a Flexi-only lock. Double-check mark type, placement, and media settings in Onyx/VinylMaster they may not match what the cutter expects.
The opinions expressed above are the personal opinions of the authors, not of HP.
Remember
To make recommendations or participate please Sign In and post a message.
Latest conversations HP Latex
HP Latex Blog
What was your overall satisfaction with LKC?
  • Very unsatisfied
  • 1
  • 2
  • 3
  • 4
  • 5
  • Very satisfied
Thanks for your collaboration
To provide additional details, click here.
